mazda mpv crankshaft sensor
Old 08-14-2011, 08:40 PM
pjhedtke's Avatar
Default mazda mpv crankshaft sensor
I have a 97 Mazda MPV . It stopped running and now only turns over but wont start . There is no spark and the fuel pump does not kick in . What can be the problem ? I was told it could be the crankshaft sensor . Does anyone know how to test them or know what the voltage is suppose to be for that . I do have a voltage meter but need to know the voltage . Anyone out there have any ideas or answers for me ?
Old 11-28-2011, 09:52 PM
Sailor1's Avatar
According to my Chilton manual:
1. Diconnect the negative battery cable
2. Unplug the crankshaft position sensor wiring harness
3 Uusing an ohmmeter measure the resistance between terminals A and B.
4. The measurement should read 950-1250 ohms at 68°F (20°C)
5. If not as specified, replace the crankshaft position sensor
Hope this helps. I am having trouble with my 97 MPV as well. I have spark, but fuel pump won't run unless i jump the FP and GND terminals on diagnostic connector. Still trying to work that out. Please post if you crank sensor is the culprit.
Old 11-29-2011, 07:34 AM
pjhedtke's Avatar
Default Crankshaft sensor
Hi
I found out it was not my crankshaft sensor .
The problem was that the timing belt broke .
Was an easy fix once I found someone that knew what they were doing
The timing belt only costed me around $40 I got it from an Oreilly auto parts store
Hope this helps you
Old 11-29-2011, 10:28 AM
Notsure's Avatar
Professional Mechanic could start the car - Please i need some diagnosis advice for my Mazda 323F GXI, 1.5cc, year 2000.
I bought new battery as the frustration was too much for me and all the embarrassment on my street. The brand new battery still did not start the car and also jump starting does not work anymore, there seems to be something blocking the car from starting.
The breakdown service spent almost two hours trying to start it. He did not have the car diagnostic equipment for Japanese, all the checks was done manually.
His own fully diagnoses are below.
None start no switching at injectors no spark at spark plugs and no fuel pump. No live to fuel pump but live at injectors and coils. Please help.
bizurk
08-06-2010 03:02 AM
lm6873
10-16-2007 02:49 PM
mcagg
07-03-2007 05:27 PM
626mazdaspeed
06-26-2007 07:24 PM
gerbstat
12-26-2005 10:43 PM
Quick Reply: mazda mpv crankshaft sensor
