92 MPV 3.0 Heat Problem
Old 11-19-2014, 08:16 PM
pastorrandy's Avatar
Default 92 MPV 3.0 Heat Problem
Van was running great. Running down interstate at about 68 mph and it started running a little warm. Eventually ran hot. Let it cool, changed thermostat, checked water pump, it was fine. Now it is running ok, but very little heat inside van with engine temp at normal range. Wondering where else to search for problem? Thanks
Old 11-19-2014, 08:29 PM
hixx's Avatar
Was the coolant rusty? It sounds like some deposits in the cooling system got dislodged and the heater core is partially restricted. You can flush it with a garden hose and a nozzle with a small tip,cone shaped. Clamp off the two heater hoses going into the firewall and remove the hoses from the heater core. Flush it in both directions. There are other possibilities but that fits with the episode.
Old 11-19-2014, 08:48 PM
I'm not sure if the coolant was rusty or not it was in the middle of the night at a rest area. I will try the flush-out tomorrow. thanks so much for the advise!
deak
04-09-2015 10:04 PM
epi4561
04-09-2015 07:37 PM
jarrison
09-12-2011 06:59 PM
EdgarMazda
07-21-2011 05:56 PM
dagresh
06-04-2007 02:43 PM
Quick Reply: 92 MPV 3.0 Heat Problem
