2000 Mazda Millenia
2000 Mazda Millenia
Hi guys, new to the site. I am having an issue with a 2000 Mazda Millenia with the 2.3L miller cycle engine in it. Last week the cel light started flashing and it was running bad, pulled codes out of the computer and I got 4 P0105 map sensor code, P0306 cylinder 6 missfire, P 0421 warm up cat efficiency bank 1, and P1524 charge air bypass. We cleared the codes and ran the car and the only code that has returned is the P1524 code. The car is not missing anymore, but it does not have any power at all. It runs but it is almost like the supercharger is not working. Did a bunch of tests on it based off the computer codes and came up with nothing. Not sure were to go from here, like i said it just seems like the car has no power at all, but does not seem to be missing anymore. One other thing i noticed is that when you start the car in the morning after sitting all night it blows a lot of white smoke out of the exhaust, after running it for a few minutes the smoke calms down, but is still there. The smoke that is coming from the exhaust smells like burnt oil. This car sucks to work on, not sure what to do. If anyone has any ideas please let me know.
I have not got any of the 0173/etc codes yet. I did check over alot of the vacuum lines I know there are a ton on this car and did not find any major leaks of broken lines. What do you think about the P0421 code could that be the root of my problems or is that just a code I should not bother with. I know the 0421 code has been in the car before, and it seems to come and go. It will be there for a while then clear itself and then come back later. I know this car has not had high test fuel ran through it 87 octane most of its life. Could that be causing some problems, and I am not sure if the plugs have been changed of fuel filter. The car has 113K on it and not very sure about the service records on the vehicle. What do you think about the smoke that comes from the exhaust apon start up, and the burnt oil smell coming from the exhaust. This car is driving me crazy and im not sure what to do with it. Let me know what you think. Thanks
no major vacuum leaks? a tiny crack can cause a big problem. if you found leaks, then there probably are more
the smoke from the exhaust should be blue or dark, if it is white, i would think that is coolant. if you are losing coolant, then you have a really big problem. was the car ever overheated? the smell of burnt oil could be oil dripping on the exhaust. is the car using oil?
Just to verify the right bank is the front bank or rear? As far as I know the car has never been overheated, but I do know the car is using oil. When I first pulled codes from the vehicle there was a cylinder 6 misfire. It is like the car is just running on the motor with no supercharger. I have worked on this car in the past and remember it having a lot of power. Like I said I did not find any kind of vacuum leaks, but I guess I could be missing one. Like I said I dont know if the plugs have ever been changed or the fuel filter either. Can you think of anything else.
The belt and compressor are still turning. Like I said the car has never overheated, but it does use oil. The abv is the cylinder looking component on the top front of the engine that has the rod coming out of it correct. If I plug off the vacuum hose it will generate boost correct.
http://cgi.ebay.com/ebaymotors/95-97...Q5fAccessories
in the picture of the motor, the abv is in the 3 o'clock position. if the cover was on the motor, it would be about under where the green 'cycle' of miller cycle is. the brass 'hat' is the diaphragm that operates the valve. you should first check vacuum from various connections in the vacuum system to verify you are getting good vacuum. at idle, you should be getting about 18-20"
Hey kennin thanks for all the help. I looked at the abv yesterday and found one of the numerous vacuum lines going to it to have a leak. I repaired the vacuum line this morning. The car has been sitting idle for a few days now, and when i started it up this morning it began to miss. I took it for a ride and it smooths out above about 2500 rpm and it seems like it got its power back. When I got back from the ride the cel light began to flash and like i said the missfire is only there at idle, once you give throttle it seems to clear itself up and run a lot better. I noticed after coming back from the ride a bad smell coming from the exhaust, and the code I pulled this time is misfire on cylinder 6 P0306. Cylinder 6 is the last cylinder on the front bank towards the drive side correct. I still havent pulled the plugs yet, kinda dredding that job. Do you think it could be a plug or more likely the coil for that cylinder. Like I said the miss is only there at idle. Any suggestions would help. Thanks
