01 S cylinder misfire
Old 07-19-2010, 10:24 AM
africansteve's Avatar
Default 01 S cylinder misfire
01 S throwing 301 code. Runs rough and engine light flashes, then burns steady, then flashes both at idle and while driving. I found and fixed 2 vacuum leaks and changed #1 coil and it ran great for a day then started chugging again. New plugs, injectors are clean. Am I looking for more vacuum leaks or something else? Thx
Old 07-19-2010, 10:31 AM
keninn's Avatar
what plugs did you use? and be specific with the part number. was the coil new? since the code is cyl specific, most common is the coil or the plug. are there any other codes?
01MPV
05-17-2007 01:44 PM
MrMan
01-24-2007 06:08 AM
CardsFan420
11-08-2006 06:25 PM
KuroRyu256
06-23-2006 10:50 PM
JJ
04-30-2005 10:39 PM
Quick Reply: 01 S cylinder misfire
