Brake Issue?
Brake Issue?
Hello everyone. I have a question regarding an issue that just came up with my brakes. I have a 2013 CX-5, Sport. It now has 53,000 miles on it. I took it in for an oil change this past Thursday. As expected, the technician told me that I would have to replace my tires before the upcoming winter, and that my brakes were nearing replacement as well.
He mentioned that the front brakes had 7 mm left on them, and the rears had about 3-4 mm left. Fast forward to today, and I noticed a definite churning/rubbing sound coming from the rear right tire. Upon looking, I noticed some brake dust on on the rims, as well as some shininess to the rotor, and some light scores. This is usually indicative of worn pads, and time to change the brakes.
I wouldn't be questioning this if I literally just went to the shop 4 days ago, and was told the brakes still had 3-4 mm left. Did they measure them wrong? Are there any other plausible ideas of something else being an issue?
If you pads are worn, aren't you supposed to hear a high pitched squeaking sound from the tabs rubbing against the rotor? I haven't heard that up to this point. Any ideas or tips before I jack the car up and take the tire off for a closer look? Thanks.
I get a ton of brake dust on my rims and my pads are fairly new. You have alot of miles.
Change all pads and put new rotors on front and possible rear ones turned. Get quotes on turning vs new ones. New is always best. I just changed pads once and they didn't last 1/2 as long, then i went all new everything.
You're definitely into metal on the rear rotor pictured. By way of explanation as to how it might have occurred without first warning you with the sound of wear tabs hitting the outer edge of the disk: my experience with Mazda is that they "cheap out" on the number of tabs at each corner, only using them on one of the two pads. I haven't had the brakes on my CX-5 apart yet, but this is the way it's been on the two Miatas I've owned and I suspect they do it this way on all their cars. Needless to say, if your pads don't wear evenly from side to side on any one caliper, you're screwed!
Rear Caliper
After trying to replace the pads, I discovered that the rear passenger caliper is completely seized up. This is a known issue with the 2013 CX-5, after doing a quick internet search. Since I'm at 52,000 miles though, obviously the work isn't covered.
That being said, I am having a heck of a time trying to find a rear passenger caliper for my model car; 2013 Mazda CX-5 Sport AWD. Does anyone have a good website, or am I going to have to go through the dealer? Thanks.
Oh, I tried that. Since I'm well over the 36,000 warranty, they essentially said there's nothing they can do. Since the issue with the caliper was only released as a Technical Service Bulletin, and not a recall, they wouldn't do anything for me.
Or...how about rebuilding yours? http://www.rockauto.com/catalog/more...nid=426&jpid=2
Thoughts on this, anyone?
