2000 Mazda B2500 Clutch Replacement
My truck has 190k miles on it and it's time to replace the clutch on it. Clutch slips a bit when giving the truck alot of gas, and I only have to move the pedal about half an inch to release it. What are your suggestions on a good clutch kit? (not high performance, just something that will last and under 250$) (Probably buying from rock auto, was looking at the RHINOPAC kit because of the amount of teeth things on it compared to the others) and was wondering if I should get a self adjusting kit, and if I should replace the slave cylinder, and how to actually replace the clutch itself. Thanks.
Luk makes good clutch kits, truck will deliver and re-surface your flywheel in most towns. I have Luk on my 1988 B2200. Pressure plate, disc, throwout bearing, needle bearings, pilot shaft will be included. First you must remove the transmission to get to the clutch parts. Unless there's something wrong with your slave cylinder, you'd just unbolt it and tie it up to get it out of the way.
