Mazda 323F BG 1991 - Not getting fuel
Old May 17, 2026 | 06:16 AM
Polykarpos2000's Avatar
Default Mazda 323F BG 1991 - Not getting fuel
Hello Everyone ,
I have a Mazda 323F BG from 1991 with carburetor and a mechanical fuel pump bolted to engine .
Car hasn't been started for about a year , the car was running fine before .
I recently tried starting it with no luck , fuel pump is not pumping fuel at all , all fuel lines are bone dry so i assume its not pumping at all .
Fuel tank is half full with fresh fuel .
Tried replacing the fuel pump with a brand new KYOSAN pump but still no luck , not pumping fuel at all .
Tried bypassing the fuel filter thinking it's blocked with crap , still no luck .
Also tried removing the fuel line coming from the fuel tank to fuel pump and tried feeding the fuel pump with fuel by putting the line coming from the tank to a canister full with fuel assuming it's something wrong with the tank , still no luck .
The car however starts and runs when i pour directly fuel into the carburetor , so its able to run which means it has spark .
I've run out of ideas guys , if you have anything to suggest , it would be much appreciated it !
Thank you !
Old May 25, 2026 | 01:42 PM
Sorry for the delay in welcoming you the forum. Normally several of us welcome new members you just seem to have slipped by that day?
But as I did respond today it will get some attention and a couple of our members may respond to your questions.
Old May 25, 2026 | 01:47 PM
Did you check this?
Mazda 323 Check valve | Mazda OEM Part Number BR70-42-910A
Item 12 in the assembly drawing image on this page corresponds to Mazda OEM part number BR70-42-910A
Old May 25, 2026 | 05:11 PM
Charlescrown's Avatar
Perhaps there's a carburetor problem like a stuck/blocked needle and seat. There is a small filter under the seat.
george m44
Sep 15, 2025 01:55 PM
fc moto
Mar 15, 2013 12:16 PM
RedneckDriver
Oct 30, 2008 08:41 PM
leach_family
Apr 21, 2008 07:14 PM
Glen wentzell
Dec 2, 2007 06:36 PM
