-   Wheels, Tires and other Exterior (https://www.mazdaforum.com/forum/wheels-tires-other-exterior-9/)
-   -   Change to LED headlights (https://www.mazdaforum.com/forum/wheels-tires-other-exterior-9/change-led-headlights-36431/)
demicrown Jan 27, 2016 08:52 AM
Apologies if this isn't the right place to post this, but I am wondering what is involved in putting LED headlights in to a CX-3 with standard halogens. I haven't been able to find anything too definitive, although I found a manufacturer called JDM Astar that seems to sell plug-and-play LED headlights.
Thanks for the help!
missfruitcake Dec 7, 2016 12:45 PM
Hi, you can try and check out PIAA.com or BFXenon. They've got great headlight conversion kits which are plug-and-play. Prices of selected products are also reduced. So if you're looking for quality, you might want to try looking around there.
Automan2000 Dec 8, 2016 01:27 PM
It's easy to replace them with LED, HID is more challenging because they have a ballast which is an extra box that needs to be installed so I'd go with LED. I know from experience the JDM aren't any good, they're what you would expect for a cheap Amazon brand and you'll end up spending more time fixing them then it's worth. I'd go with either of the two suggested already, you'll save money in the long run getting a good brand.
