Trouble shooting ticking noise from drivers side wheel
New member here. I have a 2006 Mazda 5. About 6 months ago I ran over something on the freeway and within a few moments had a flat tire. After I remove the tire, I noticed the him was bent and cracked. I hit something hard. Anyway, decided to get 4 new rims and tires 😁! The reason I am including this story is because I thought it could be relevant to the ticking noise that I am hearing from the front drivers side wheel well area when I am driving. The ticking goes faster as I increase speed. I begin to hear it at about 10 mph. I have read a lot of post about the same issue and I have checked several things. there is nothing stuck in my tire. I have raised the front end and put the car in gear and could not hear the sound at all. I only hear it when it is on the ground. By the way, the passengers side wheel was spinning much faster than the drivers side. I have removed the brakes to check for rocks, cleaned, greased and put them back together. With the tire on the raised vehicle, I held the tire at 12 and 6 and tries to wiggle the tire, there was no movement. I even put one of my stock rims and tires back onto the front. I've checked all the CV boots and all staring composts. Everything is good and tight. I still hear that darn ticking noise. Any suggestions would be appreciated. Thinking of replacing the CV shaft this weekend. Thank you.
Steve W
06-27-2018 04:38 PM
06Mazda5
09-02-2017 10:36 AM
cugene
04-07-2007 04:25 PM
