Help needed
Old Aug 6, 2018 | 04:47 PM
maz654's Avatar
Default Help needed
Hi all i'm having a bit of an issue with my 2008 Mazda 6 ts2 2.0
I have two codes P2463 & P242f when i clear the codes turn ignition on engine not running both codes come back within about 20 seconds
Looking for any ideas on how to fix.
Thanks in advance.
Old Aug 7, 2018 | 06:52 AM
Both relate to a blocked DPF, P242f will prevent a manual forced regen. I suggest you find someone who can manually wash out the DPF. Once that's done, you may be able to clear the codes and carry out a forced regen.
Old Aug 7, 2018 | 11:23 AM
maz654's Avatar
Hi and thanks for the reply i have had a new dpf fitted today (a friend has his own garage) and i have exactly the same fault as before.
Baffled and a tad anoyed this beautiful looking car is starting to become a bit of a pain.
Old Aug 8, 2018 | 01:41 PM
maz654's Avatar
Update. Happy to say its all sorted i bought a ELM 327 OBDii adaptor from ebay with forscan Reset the dpf learned values and reset the differental pressure sensor learned values cleared all DTC's.
All warning lights off, what a brilliant pice of kit.
Old Aug 8, 2018 | 02:21 PM
maz654's Avatar
Old Aug 8, 2018 | 03:01 PM
maz654's Avatar
VegasDriver
Jan 1, 2007 05:38 PM
cugene
Nov 14, 2006 11:58 PM
xtrigger
Aug 10, 2006 07:02 PM
bhc6
Mar 28, 2006 02:49 PM
