-   Off Topic (https://www.mazdaforum.com/forum/off-topic-4/)
-   -   The Run-mill: A Chevy Cruze Engine Change (https://www.mazdaforum.com/forum/off-topic-4/run-mill-chevy-cruze-engine-change-56315/)
Mechanically Minded Dec 9, 2025 03:49 PM
Late last night, during the mixed winter weather. A certain marketplace ad appealed to my stepson.
He has a twin brother that rearranged an Excursion's front end with his brother's 2016 Cruze Limited that we gifted to him. While Door Dashing...Bummer....
https://cimg5.ibsrv.net/gimg/www.maz...33c6f2a593.jpg
https://cimg6.ibsrv.net/gimg/www.maz...1a932b54f0.jpg
Anyway, This slid through a specific marketplace... I was sent to retrieve it.
https://cimg0.ibsrv.net/gimg/www.maz...81b24568ed.jpg
First off, the key/fob combo is damaged. And of course the battery is dead.
I am going to unload it and start checking stuff.
Nevermind the moon finger...
Mechanically Minded Dec 9, 2025 07:28 PM
After charging the battery (which held a charge) and airing up the tires. I dug around and found a new replacement key fob and new battery. (All on hand from the previous silver car.) 😃
Popped it apart and swaped in the circuit board and correct key shank for the red car.
It would spin over but not start. After priming the switch a slew of times it started hitting and missing while spinning. More hits and misses slowly gaining cranking speed and with some throttle manipulation, it did start. 😃
After warming up, I found it pushes the coolant out of the tank when capped and spews white smoke from the exhaust. Otherwise, runs good and is extremely hard to re-start. 🤔
Typical headgasket indicators. 😒
I have not tried to coolant pressure test it, but I am sure it will fail miserably and most likely hydrolock afterwards. 😬
Rather than diagnose the actual problem... (hurts my head) I will just swap engines from the silver one to the red one. Pull 2 and pretend to put 1 back in. 😉
Goal is... before New Year's. Oh... and, in the open gravel driveway. Should be great! 👍 Seeya there! 😂
MeB2000 Dec 9, 2025 08:52 PM
Well, I have no doubt that you will have it done by the 1st.......yeah, you still need that concrete slab! :)
I just had all 3 buildings here re-shingled......new skylights, vents, etc. I will finally get to work on the VW bug some on Thursday!
https://cimg1.ibsrv.net/gimg/www.maz...63d4731d4f.jpg
Mechanically Minded Dec 9, 2025 09:35 PM
Cool Bug! Good color too. What cc is it?
MeB2000 Dec 10, 2025 07:05 PM
It is the original 1600cc engine......the original fuel injection is still installed and working also. I pulled all of the injectors and cleaned them here at home.......runs good!
https://cimg1.ibsrv.net/gimg/www.maz...f0dddbc085.jpg
