so I guess the extra 30-35 miles per tank is just my imagination. oh well... as long as my imagination saves me money
Originally Posted by lnwlf
(Post 111341)
Originally Posted by shipo
(Post 111343)
Yup, absolute imagination. The fact remains that by spending the extra money on a higher AKI rated fuel you are WASTING money, not saving it.
(Post 111345)
correct me if I'm wrong, the higher the octane rating the more compression it can handle before detonation? I believe what your saying, but numbers never lie
So, while you claim that the numbers don't lie, I submit that they do. Why? Because there is no way on this earth that you (or anybody else for that matter) are a good enough driver to determine from one tank to the next that you drove under the exact same conditions and demanded the exact same amount of power from your engine in those conditions. Said another way, your anecdotal numbers of mileage improvement are statistically and scientifically irrelevant. FWIW, I drive a Mazda3 and use Regular fuel 100% of the time. I've tracked my mileage religiously for the 31,000 miles that I've owned the car and have seen tanks of gasoline run low after as few as 250 miles and after as many as 475 miles. Given that I've seen a 225 mile swing in a single tank of gas, your "30-35" extra miles is completely within expected variance for any given tank of fuel. My bet is that if you were to put your car on a dynamometer and have the Brake Specific Fuel Consumption (BFSC) calculated, it wouldn't vary even 1% between tanks of fuel, regardless of which fuel you put in your car. Long story short, save yourself some money and go back to Regular fuel. Not only will your wallet thank you, your engine will too. |
will do, will let you know how it goes in a week or two. If all is as you say, then I stand corrected. One more question... the wheelbase on the M5 is a little over 4 inches longer than the M3... do you know if an aftermarket cat-back for the three will fit underneath the 5?
(Post 111348)
that's the usual response, lol, trying to gain a little more power, not much, especially with the family in the "vagon". tossed the resonator for the intake last week and noticed a much needed improvement, 3 inch pvc slips right on the factory filter box. now that air has little restriction getting in, a little less restriction going out will help as well
(Post 111350)
While I don't know for sure, I rather doubt a Mazda3 exhaust will fit on a Mazda5. Of course you can probably guess my next question... Why would you want to put a cat-back on your Mazda5?
I'd be willing to bet the variance is more reliant on another variable than your fuel's octane: your right foot's pressure. And where you're driving. And what the environmental conditions are.
I've seen up to 38MPG highway on low-tread tires along the flat Jersey shore in the middle of July without my AC. And I've seen as low as 14MPG in the dead of February with the heater on 3/4 'cause it was colder than a witch's tit. You'd be surprised how often the many variables that go into driving are forgotten, and someone automatically assumes it's their octane. And even then...not all fuels of the same "grade" are created equal. I'd take Sunoco 87 over some no-name's "regular" any day. |
(Post 111345)
(Post 111346)
Yes, the higher the AKI rating (we don't use a direct "octane" rating to grade fuel here in North America), the more compression the higher AKI rating necessary to prevent detonation. That said, once fuel that contains the proper detonation resistance is identified, using fuel with a higher AKI rating will do nothing but waste money. In your case, your car is designed and built to use fuel with an AKI rating of 89, and using anything beyond that is simply a waste of money unless you somehow modify your engine so that it requires a higher AKI fuel to prevent detonation (something you have apparently not done).
So, while you claim that the numbers don't lie, I submit that they do. Why? Because there is no way on this earth that you (or anybody else for that matter) are a good enough driver to determine from one tank to the next that you drove under the exact same conditions and demanded the exact same amount of power from your engine in those conditions. Said another way, your anecdotal numbers of mileage improvement are statistically and scientifically irrelevant. FWIW, I drive a Mazda3 and use Regular fuel 100% of the time. I've tracked my mileage religiously for the 31,000 miles that I've owned the car and have seen tanks of gasoline run low after as few as 250 miles and after as many as 475 miles. Given that I've seen a 225 mile swing in a single tank of gas, your "30-35" extra miles is completely within expected variance for any given tank of fuel. My bet is that if you were to put your car on a dynamometer and have the Brake Specific Fuel Consumption (BFSC) calculated, it wouldn't vary even 1% between tanks of fuel, regardless of which fuel you put in your car. Long story short, save yourself some money and go back to Regular fuel. Not only will your wallet thank you, your engine will too. even if there is no difference here, you are paying more money for gas. that may not be much more, but it will be in the long run. even old gearheads will tell you that too much octane will cost you power. |
