GREDDY BOOST GAUGE QUESTION
I just bought the Greddy boost gauge and the directions are telling me to fit from the 3-way joint connector, the tube from the intake manifold, the fuel pressure regulator and then the last one to the boost sensor. I have the HKS SSQV blow-off valve and the tube from the intake manifold connects to the blow-off valve. My concern is, if I hook up the boost gauge the way the directions say, I'll have to disconnect the intake manifold tube form the blow-off valve and connect it to the 3-way joint which will leave an open connection on the blow-off valve. Is there a way around this or would it work if I just cut the intake manifold line and put a t-connector in it and run it to the boost sensor? I would appreciate any help, thanks guys.
Dale 2006 Mazdaspeed 6 |
