Tribute trans problems
Hello, New to this site.
I have a 2004 tribute 4 cyclinder. On 1st gear when releasing the clutch pedal my engine or transmission shakes very bad. I usually have to take off on 2nd gear to avoid this shake. It also happens when backing up. 1st gear and Reverseshakes bad , 2nd, 3rd,4th,5th are all ok.
And this only happens more often than sometimes. Hope you all can help with this issue.
RE: Tribute trans problems
Check the motor mounts on your front wheel drive engine. If it only happens on first or reveres it has to be a mount problem. Trans problemsoccur on all gears not just one. Unless it is a linkage that is bad.
Mechman12867
07-09-2005 11:06 PM
