Newbie with Miata engine stumbling problem (1993 Model)
Old May 29, 2015 | 06:56 PM
jamescreel's Avatar
Default Newbie with Miata engine stumbling problem (1993 Model)
Hi All!
First of all I grew up with Mazda's. My family had a B2000 truck, a GLC, and a 323. We also owned a Ford Courier truck which was a Mazda. Good tough autos!
My neighbor gave, yes gave me a solid 93' Miata. It's got a bunch of mile but it seems OK. And it promises to be a fun car!
The engine stumbles under load. And it appears to stumble while in a left turn (go figure).
I have replaced the air filter, plugs, wires, and the fuel filter. The fuel is fresh as I ran the stale out. I am hesitant to believe the engine is experiencing a mechanical fault as when it is not stumbling it idles smoothly and will rev effortlessly to redline.
Any suggestions would be appreciated,
JRC
Old May 30, 2015 | 07:08 AM
Replace the ignition coil/coils. clean the MAF, clean the throttle body, check the fuel pressure, check the ignition timing, check for fault codes in the ECU/PCM.
Old May 30, 2015 | 10:17 AM
It's old and may be experiencing a clogged cat too. In my experience a car with a clogged cat will idle nicely, but under load as you stated is when backpressure will build up. Try temporarily removing the cat and if that makes a difference. If it does either replace it with new, or run lacquer thinner through it several times to clean it out. I have to admit that I have no personal experience with this trick but have been told it works. And if the cat is really bad, what harm could it do to try it?
2003mx5se
Aug 1, 2014 08:18 PM
VilaRomeo
Jan 20, 2010 06:46 PM
yoshi77!
Sep 26, 2008 08:58 AM
larry6144
May 11, 2008 10:34 PM
dirtyedge
May 2, 2007 06:02 PM
