COOLANT TEMP/OIL PRESSURE SENDING UNITS
Old Feb 16, 2007 | 07:54 PM
jgonzalez261's Avatar
Default COOLANT TEMP/OIL PRESSURE SENDING UNITS
Hi to all from Homestead, FL. I'm new to the forum. I just got done rebuilding my 1990 Mazda Protoge 1.8 DOHC engine. All is running great, but for some reason my Coolant temp and oil pressure sending units are malfunctioning. The coolant temp sensor doesn't register at all, even after the engine has warmed up. The oil pressure sending unit remains on all the time. I have proper oil pressure. I may have switched the wiring, although I think that's highly unlikely. I have a Haynes repair manual, but the wiring diagrams don't depict the wiring schematics for these two sensors. Can anyone help?
Thanks.
Javier
Old Feb 20, 2007 | 02:37 PM
babyhuey's Avatar
Default RE: COOLANT TEMP/OIL PRESSURE SENDING UNITS
Does sound a little improbable that the wires would be switched as the oil sender is on backside of block by the oil filter and temp sender is up front by the upper radiator hose connection.
A good indication that they might be switched is that the temp gauge would probablyregister full hot with key on, engine off but drop to full cold once you start the engine.
Both sensors use a single pin, single wire connection so switching could be possible. Wire for oil pressure switch is Yellow with a Red stripe. Wire form the gauge temperature sender is Black with a Orange stripe.
dwcraig
Mar 15, 2015 04:10 AM
cep623
Mar 3, 2008 08:02 PM
dwmcqueen
Feb 12, 2007 12:15 AM
sting
Jun 25, 2006 11:18 PM
jolt
Apr 28, 2006 06:44 PM
