Cam Position Sensor Voltage ???
Old Jul 10, 2019 | 12:23 AM
Chris Heap's Avatar
Default Cam Position Sensor Voltage ???
Gday, My 2013 3.2Lt BT50 continually goes into Limp Mode at 2000 revs, the scanned code indicates PO341-62, Have replaced the Camshaft Position Sensor and cleared the code with no luck, the car is becoming more sluggish to drive. I need to know what voltage is required at the sensor to check if its getting the correct signal please ????
Old Jul 10, 2019 | 05:43 AM
Just checking, this is the sensor in the side of the head, just below the fuel rail, beside the EGR valve?
Old Jul 10, 2019 | 05:56 AM
Don't have any figgures, but, try this
INSPECT CMP SENSOR CIRCUIT FOR OPEN CIRCUIT
• Switch the ignition to OFF.
• CMP sensor and PCM connectors are disconnected.
• Inspect for continuity between the following terminals (wiring harness-side):
― CMP sensor terminal 1 and PCM terminal C2
― CMP sensor terminal 2 and PCM terminal K3
― CMP sensor terminal 3 and PCM terminal D1
• Is there continuity?
Old Jul 10, 2019 | 05:58 PM
Chris Heap's Avatar
Yes mate
Old Jul 11, 2019 | 01:12 AM
Chris Heap's Avatar
What does the 6 7 8 mean on the diagram ??
Old Jul 11, 2019 | 03:01 AM
Not sure, don't worry about that detail.
Old Jul 15, 2019 | 03:04 AM
Chris Heap's Avatar
This plug connector is not the same as whats on my ECU, i cannot check continuity until i have the correct plug diagram, thanx anyway, Cheers
Old Jul 16, 2019 | 03:03 AM
There will be 3 different plugs on your ECU.
Old Jul 16, 2019 | 07:27 PM
Chris Heap's Avatar
Yes thats correct, none of them replicate your diagram below, so could not check continuity
Old Apr 30, 2024 | 03:38 AM
jakeroco's Avatar
Hi Chris, what ended up being the fault with this BT50 ? I have one doing exactly that.
