Air intake not working on my mazda protege 2000 lx
Ok so i got this after market air intake and my car will turn on for a lil bit then turn off . I dot get why its doing this. If any one has legit opinions
Originally Posted by DUSK0809
(Post 127775)
I just got this car and trying to modify it and add some speed to it. I was thinking it was the maf but not sure
You may not want to believe it, but the new intake won't do anything for the performance of your car.
This is the advice you need to actually help you with what your doing:
Cleaning the MAF with MAF cleaner would be a good idea. You should also clean the Throttle body with throttle body cleaner. Before you do these things, unhook the cable from your negative battery terminal (disconnect negative terminal), then depress brake pedal for 10 seconds-----now you can clean MAF, etc. Make sure both MAF and throttle body are dry before starting. Even if you don't clean MAF you should still disconnect negative battery terminal so computer can re-learn your new intake. reinstall negative terminal. Start car and let idle for 10 minutes. If you are still having problems after driving a couple days, then you have a lousy intake. The MAF should be in a straight section, otherwise you may have problems. Tighten all clamps on intake. https://www.mazdaforum.com/forum/mem...eaner-2203.jpg |
| All times are GMT -5. The time now is 01:25 AM. |
