84 B2000 Ute
Hi. Why has the dashboard and indicators suddenly stopped working? Fuses are fine. Any advice on how to sort this issue out would be great. Cheers
Interesting that the fuses are good that would have been the first thing to check. Have you done anything that might have caused it: installed anything electrical, hit a huge pothole, find any evidence of mice?
The next thing to look at is the wiring looking for something that might have caused some damage to the wiring. I would also double check the fuse since this is the easiest thing to fix.. Any other suggestions from those with more experience??? |
Last week i removed an old sterio cd player and speakers that the previous owner had installed...
Maybe i should take her in to an auto electrician |
I think you found the source of your problem.Check your work first. Make sure everything looks right. Did something get knocked loose when you were removing the system?
By the way, what part of the world are you in? There seems be Richmonds everywhere. |
So, it turns out that after giving the contract points in the fuse box a good wipe and clean....everything is tip top again.
thanks for your help, guys. |
Richmond, South Island, New Zealand :)
