2014 3 touring needs help
I'm a proud owner of two Mazda's, both have been trouble free but the 3's
front right speaker in door and tweeter on dash has stopped working.:confused: The back right speaker does work. My first step will be to test the speaker in the door with an ohm meter - and replace it if needed. I'm hoping the problem is with a connector common to both of the speakers. My car does not have the Bose system. Does anyone know where the audio power amp is located in a 2014 3 touring sedan? Thank You! |
Have you tested the speaker yet?
Have you swapped the front speakers side to side to confirm if it the speaker at fault? |
I did pull the dash corner cover off to find that there is no speaker there just a blank cover where the speaker should be. So now that I've learned that my car only has 4 speakers I will buy two new front door speakers and maybe the back door speakers later on. I'm still deciding if I want to buy component speakers and run wires to the dash for the tweeters or just get a good pair of coax speakers which would be easier to install.
