2010 mazdaspeed 3 2.3l turbo engine knock.
Old May 4, 2020 | 05:55 PM
Eric Steigerwalt's Avatar
Default 2010 mazdaspeed 3 2.3l turbo engine knock.
So this is my first mazda. On my way to work today my speed lost all its power and was barely running. And the engine was knocking. I limped it to work and plugged the scanner in it. It through codes for a misfire in cylinder 3 and crankshaft sensor. Changed the plugs and replace the coil pack. Started it up, the engine still was knocking and still throwing code for misfire in cylinder 3, but was no longer throwing the code for crankshaft. Is it possible for the crankshaft sensor to make the engine knock. Any help would be much appreciated. Thanks
Old May 5, 2020 | 06:33 AM
Swap the spark plug & coil to cylinder 4. Clear the code, start engine & see what code you get. If its still cylinder 3, try swapping the fuel injector to cylinder 4.
Sal_Cadena
Jul 15, 2017 09:54 PM
Dmaher1878
Jun 26, 2016 10:35 AM
JRN
Oct 22, 2015 07:46 AM
KyleG
Oct 17, 2011 03:44 PM
