1993 miata clutch or trans.
I have a 1993 Miata. It won't go into gear. The clutch is 2yrs old. replaced clutch master cylinder and slave, no help. adjusted pedal height and pedal free play. no help. Any Ideas??
Master cylinder, plumbing, slave cylinder, and connection to the throwout bearing all constitute "Linkage" in my book. Pretty much everything in between the clutch pedal and the clutch disc qualifies.
Your right Shipo, my bad. linkage at the pedal looked good when I adjusted the pedal. My problem didn't start until I replaced the slave because it was leaking. Maybe if I re-build the leaky slave, my problem will go away.
