1990 mazda b2600i bogging down under acceleration
Old Apr 21, 2021 | 03:26 PM
claytonray's Avatar
Default 1990 mazda b2600i bogging down under acceleration
got truck used had blowed headgasket. brand new head all new intake and exhuast side gaskets block is within spec. deff in time have set it 10-15 times and checked it with my timing light. truck starts idles perfectly. give it throttle very very slowly itl rev as high as u want it to give it throttle like you would to pull out it just cuts out backfires and chokes out never does die though. timing advances when u give it throttle. new plugs wires have distributer on way tried 4 diffrent ecms......same symptom have tried doing the check for engine codes but cant get that to work at all. plugs seem to be very rich but that was after i had been trying to get it to take throttle. any suggestions? truck is a 1990 b2600i has a little under 180k no rust on truck anywere 5 speed would really like to fix
Old Dec 31, 2024 | 07:39 PM
Coopers's Avatar
I know this is a long shot but did you ever fix this issue. Mine is doing exactly the same thing
Old Dec 31, 2024 | 08:26 PM
claytonray's Avatar
Default Hey
Gona sound crazy but change fuel pump there 2 stage “low and high” can fool u ins heartbeat bro. Fixed mine right up. An advance oriellys fuel pumps go bad constantly
Old Dec 31, 2024 | 09:11 PM
Coopers's Avatar
Thanks mate. One of the issues that I had was very rusty fuel so I removed the pump and raised it about an inch hoping it would fix the problem of pulling **** from the bottom of the tank. Fuel now comes through clean but maybe the pump is full of rust. I’ll get a new pump and try it. Thanks again for your help
bubbacakes
Feb 19, 2026 06:48 PM
B serious
Jun 16, 2019 08:55 AM
b1004
Oct 30, 2007 08:43 AM
dwb
Apr 28, 2006 01:52 AM
