Window clicking...
Old Mar 28, 2007 | 02:54 PM
t0md0's Avatar
Default RE: Window clicking...
no i didnt quite see a TSB for my year and make.
i understand that TSB stands for Technical Service Bulletin but what exactly does this mean? is it justa notification toother drivers of what"can" potenially cause problems because it happens to some andnot all mazda 6's?does it also mean dealers fix TSB's?
Old Mar 28, 2007 | 02:55 PM
t0md0's Avatar
of course they'll fix it... i meant to say, will they'll fix it free of charge?
Old Mar 28, 2007 | 04:08 PM
sstlaure's Avatar
To remove your front door panels
1) Pull out cap cover inside door release handle opening (small screwdriver), then remove screw
2) remove inner handle cover
3) Remove inner garnish panel
4) Remove cover inside door pocket (where you grab to pull the door closed), remove screw
5) Remove lens cover at lower back corner of door trim, remove screw
6) Disengage clips around perimeter of door (straight out)
(3) along front edge, (1) at front bottom corner, (2) along bottom edge, (1) on back edge, (1) in top rear corner
7) Door trim has (2) hooks that catch along the top edge, pull the bottom of the door trim out, then up.
8) Disconnect power door mirror switch & power window switch connectors
9) Disconnect the wire harness going to the courtesy light
Good luck (taken from the factory manual)
Old Mar 28, 2007 | 04:53 PM
t0md0's Avatar
thanks sstlaure, but i acutally already know how to remove the door panel. its actually getting to the regulator part that i was curious about. after removing the panel i notice there is also another big black plastic panel inside screwed on by some big bolts and i was more concerned if i also had to remove that in order to get to my window regulator.
Old Mar 28, 2007 | 05:01 PM
sstlaure's Avatar
Let me look at the manual real quick....
It's too hard to explain this via words...Do you have an email address I can send some .pdf files to? PM me with the info.
HerrKaLeun
Aug 4, 2013 08:34 PM
93mx3
Jun 21, 2006 11:45 PM
Hadrien
Jan 18, 2006 07:41 PM
crmx0312
Dec 22, 2005 11:18 AM
bitnick07
Apr 12, 2005 12:09 AM
