warning light
hi.got a problem with my mazda 6 2.2d 2014.126500mile
on dashboard red triangle says- Low oil pressure Possible engine damage Check oil level so i change the oil check oil pump all looks good decided delete the light,did that make 50 mile light start again.... who knows please hellp. https://cimg5.ibsrv.net/gimg/www.maz...fd1fe79486.jpg engine got power but noisy when its cold... maybe it oil pressure sensor but not sure.... |
Tow it to Mazda. Don't start it, don't drive it. These SH engines are troublesome.
no no i will di it my self i dont trust mazda service last time mazda service fix wrong think....
Buy yourself a decent scan tool & start diagnosing.
If you don't trust Mazda, then Good luck. ================================================ More than likely your engine is ****ed & will require replacing. Not sure on Mazda UK, but in my market these engines are failing left, right, & centre & Mazda is replacing them even if they are out of warranty. |
i did diagnostic and kt no problem with engine all good.
probably can be a sensor |
Don't understand why you would post a question on a forum then dismiss the advice you received.
If you have used a diagnostic code reader that found no faults ("all good") then it won't be a sensor, are you sure you've got oil pressure? as Reaper says, don't run the engine if you've none. |
