Tire Pressure
Does anybody know off the top of thier head what the recommended tire pressure for the
Talon TR 968 tires are for the 6? Triangle 215/50R17. Its prolly in the manual but i will check tommorow. The side of the tire said max load 1346 lbs at 51 psi, but that seemed a little high Thanks,Doug |
RE: Tire Pressure
If I remember correctly the recommended PSI is 32.
RE: Tire Pressure
Look for the tag on the "b" pillar of youLF door. It list the recommended pressure... then add at least 4psi to that. Mine is 32/32, but w/the Falkens I was running 38/31 seemed best. Now w/the Kumho's I'm running 40/33. |
