Thick White Frost on A/C Line
Old Sep 16, 2008 | 04:13 PM
FlaBlueSkys's Avatar
Default Thick White Frost on A/C Line
TheA/C Line (metal hose) that comes off the firewall and travels along the passanger fender,was completely covered in thick white frost (maybe 1/8"-1/4" thick). I opened the hood to have a look, after the a/c fan stopped blowing inside the car. I could still feel cold air, but nothing was circulating. Any thoughts?
2004 M6 2.3 ATX[/align]
Old Sep 16, 2008 | 05:03 PM
MazdaChef9's Avatar
Default RE: Thick White Frost on A/C Line
Have you been using your ac for a long time than possible shut the car off so it cools, than start the car up and blast the ac again?Was thison a fairly warm day? If so it may be condinsation that has built up in the line. Then when you started the ac up for the second time it froze the water and sealed off the line. Or you may have a small crack in the line and be leaking freon.
Old Sep 16, 2008 | 05:53 PM
Was driving the car at highway speeds for 1/2 hr on a warm (85) day.
Old Sep 19, 2008 | 05:59 PM
davidteachey's Avatar
One possibility is low freon. Another is if you had a majority of the vents closed. Anyone with other thoughts?
David
Old Oct 15, 2008 | 08:13 AM
Recently replaced a not functioning ambient air temp sensor. Have not had a repeat of theproblem. Now I'm wondering if that sensor has an effect on the a/c ventilation system? Maybe sends some signal to the computer to control a/c temp changes? Any thoughts out there?
MABE2007
Mar 2, 2011 04:21 PM
starks252
Oct 26, 2008 07:36 AM
Brodereick
Oct 16, 2006 07:23 PM
d8nk
May 29, 2006 03:59 AM
vizz
May 7, 2006 03:54 PM
