Squeaking Brake Pedal?
Old Dec 20, 2006 | 01:51 PM
davidteachey's Avatar
Default Squeaking Brake Pedal?
Good morning,
I have an '04 Mazda6 Wagon, and I'm noticing the brake pedal to be very squeaky. I got down in the footwell and could tell that the squeak seemed to be coming from the "accordioned" rubber diaphram between the pedal lever and the firewall. I couldn't see anything that I could apply lithium grease to to make the squeak go away. Have any of you experienced this? Is there a known solution? Thanks,
David
Old Dec 21, 2006 | 11:54 AM
dborten's Avatar
Default RE: Squeaking Brake Pedal?
Ihave same problem on '04 6S Sedan. I have not tried to oil the rubber boot...I just turn up the audio.
I will check back to see if others have same prob and if anyone has a quick fix.
Dan
Old Dec 24, 2006 | 01:48 PM
Thanks Dan...turning up the audio seems to work for me too! Cheers,
David
Old Dec 25, 2006 | 03:50 AM
JBix's Avatar
Probably has something to do with the brake booster or the linkage between the pedal and the booter. At leas that's my guess. I guess the radio helps too.
Old Dec 27, 2006 | 04:20 AM
wagonboy's Avatar
Had the same deal on my 2005 wagon. Flushed the brake system, put in new fluid, problem solved!!
Old Dec 30, 2006 | 08:43 AM
everythingzen's Avatar
yea! i have the same problem!!! it comes & goes on my 05' automatic 5-door w/sport pckg....but it doesn't bother me......i do seem to have a sqeaking noise when i'm in park and idling...whats up with that?
[IMG]local://upfiles/2802/A3899E3DEBD64466A855BC0B7532BAF3.jpg[/IMG]
Old Dec 30, 2006 | 08:46 AM
**** guys...sorry i messed up.....
i meant to say that i have a squeaking noise only when i'm in idling in DRIVE...like @ a red light or at a stop sign....sorry.......
[IMG]local://upfiles/2802/809761A887134628B31534178588EC00.jpg[/IMG]
Old Dec 31, 2006 | 10:34 AM
zoomnbyu's Avatar
I lube the boot/grommet at the firewall about 2 times a year for this. [8D]It is tempurature sensative - hot weather really gets it going. A little silicon spray goes a long way and won't attract too much dust and dirt like heavy lubes do.
Old Jan 13, 2007 | 12:40 PM
Zoom Zoom's Avatar
mine does the same too, on and off... Mazda says there was no fix for it currently, but I will check with other dealers....
Old Jan 16, 2007 | 09:07 PM
babyhuey's Avatar
wagonboy has the right idea. Check this link to TSB for squeaking brake pedal. No fix available????
http://www.finishlineperformance.com...05-06-1654.pdf
