Side ground effect panel-how to reattach?
Old May 12, 2005 | 09:39 PM
exiledtiger's Avatar
Default Side ground effect panel-how to reattach?
Won't go into details (wife did it) - the ground effect panel on the passenger side, the bottom stylish piece that goes from the front wheel well to the rear wheel well on the bottom of the car, got whacked. It is loose at the back, looks like some clips were broken. I don't see any screws to remove, and as it fits into both the wheel wells, it doesn't seem like it can slide forward or backward. How do you get it off and then how do you reattach it? Do you just rip it off and get all new clips when they break?
Old May 13, 2005 | 10:33 AM
Fragile's Avatar
Default RE: Side ground effect panel-how to reattach?
I was thinking it clips in a couple of places and screws in a couple of places. If clips are broken, you will need to replace them. You'll probably need to order through a Mazda parts department, but they shouldn't be very expensive.
Old May 13, 2005 | 06:37 PM
Patrick's Avatar
Administrator
indeed...call the parts department of your local dealer and ask them what holds the rear section of the lower rocker panel cover on.
Patrick G
May 27, 2015 05:23 AM
EthereaL
Apr 30, 2008 09:00 PM
Lupae3s
Dec 13, 2006 11:10 PM
92mazdaman
Nov 13, 2006 02:13 PM
MichaelDunn
Feb 20, 2006 09:50 PM
