Shifter no "p" indication
Old 07-18-2017, 04:26 PM
Da hamma's Avatar
Default Shifter no "p" indication
My 2012 6i is at times sluggish to move shifter into park. It is an AT trans. The car goes into park but the light doesn't illuminate. If I jiggle the stick sometimes it will light up. When I go to start the car if the park light isn't on it will not turn over. I override the shift lock put the car in neutral and it starts.
There are no MIL CEL indications.
Any ideas. I've read where it could be the cables or the neutral interlock.
Thanks for the input. Any questions please ask.
Old 07-19-2017, 05:14 AM
Sounds like it's time to replace the shifter assembly.
Old 07-19-2017, 08:21 PM
Da hamma's Avatar
That's what I was thinking. I found very limited info on a few forums related to broken switch actuators or stretched cables. I'll open it up this weekend to see if there is anything obvious interfering ie coins, dirt...etc.
If I do replace the assembly, is there anything I need to do to ensure the cables don't change position or gears while disconnected?
Thanks for the assist.
Old 07-29-2017, 04:42 PM
WILLIAMCOLLINS1995's Avatar
Find where the cable comes in and attaches to the gear selector / tcm. Take it off and clean it up (I use a die grinder, you could probably use sand paper) re-install and it works 90% of the time.
Old 07-29-2017, 07:29 PM
Da hamma's Avatar
Thanks for the reply. I'll try that. I plan on taking it apart in the next few day.
isn't the die grinder very aggressive for cleaning up the cable? Was yours rusted?
Old 07-30-2017, 11:48 AM
Sorry I wasn't specific enough. you shouldn't have to clean the actual cable, its a plastic bit at the end that connects to the tcm. Theirs a little metal paper clip retainer type of thing that goes through the plastic piece you just have to take that off and remove the cable. Then with the die grinder clean off the metal **** that the actual cable attaches to. just with like an abrasive disk on the die grinder. The problem with them is just that they begin to rust. I don't actually own a Mazda, I'm a tech at a Mazda dealer.
Old 07-30-2017, 02:06 PM
Da hamma's Avatar
Thanks for the info. So you are referring the the end of the cable attached to the trans not the end inside the cabin.
Old 07-30-2017, 09:47 PM
Right
montanaman
03-31-2018 11:11 AM
yaelgor
09-22-2017 10:48 AM
KB3
10-11-2012 12:03 AM
mx5mke
10-25-2009 11:11 AM
Quick Reply: Shifter no "p" indication
