rpm's
At 80mph, where should the rpm's be at?
is it 3000 or 4000? I drive a 6i 2.3 |
RE: rpm's
why is there a problem?
RE: rpm's
for my 3.0L mazda6, i sit around 2600 rpm on a flat road. when there is more resistance (wind or such)... i sit around 3000
RE: rpm's
I also have the 6i, 2.3 (2006)....mine is usually around 3000....sometimes a little higher or lower depending on the wind
RE: rpm's
2006 6i 4cyl 5 spd. RPMs are at 4000 at 80mph in 5th gear. Wind has nothing to do with it.
Mark in MA |
RE: rpm's
So 4000 rpms is normal then
Doesn't that suck more gas then Going 3000? |
RE: rpm's
yes it does.
RE: rpm's
ORIGINAL: sstlaure yes it does. While we're stating the obvious, 60mph uses less gas than 80mph as well. Mark in MA |
RE: rpm's
ORIGINAL: mazda69 So 4000 rpms is normal then Doesn't that suck more gas then Going 3000? If your actual question is "Is a manual at 4000 more fuel efficient than an automatic at 3000?", the short answer is yes. The manual is not losing energy to the torque converter, nor is it downshifting on a regular basis like the automatic. My manual spends most of its time on cruise control at 80mph (4000 rpm), and I challenge any automatic to beat my 31mpg. Mark in MA |
RE: rpm's
now i would like to know what kind of gas milage your manual would be getting at 65mph while you are still above the 3krpm vtec whil mine being an auto is below that vtec setting, wich makes it use less gas....
that would be interesting, when your car is running in the vtec it runs 1k more rpm than mine but uses less energy to get better gas milage. but if i was running slower out of the vtec, and you were going the same speed in the vtec i wonder wich would do better... anyone ever try this. i know when i run with traffic (70-80mph) in my auto i get 27.79 mpg when i run at 65mph i get 33.23 mpg these are all three tank averages thats almost 6mpg better running out of that first vtec setting since the manual is only rated at 2 or 3 mpg better than the auto i wonder if its true even at 65 |
