Rear brakes mazda6 Sportwagon
Anyone ever done a full brake job on their 6 before?
I'm doing front/rear brake jobs on my wife's 6 Sportwagon this afternoon. I've got the fronts done, but the rear calipers (according to the service manual) have an Allen head bolt somewhere on the caliperthat somehow retracts the piston into the caliper. I'll be damned if I can find the Allen head. The diagram makes it look like you just spin the piston counterclockwise back into the caliper...Is this correct? I'm having one hell of a time figuring out the rears.
Anyone with input? I've done dozens of brake jobs and have yet to come across a caliper like this.
No allen head bolt on the 6 rear calipers sstlaure. Rotate the piston clockwise untill it just bottoms out as shown in the drawing below. I know you do not have the special tool so try using a pair of needle nose plies to engage the cutouts in the piston. Once both side are installed just step on the brake pedal several times and the rear pistons should seat themselves.
[IMG]local://upfiles/1377/87C707F7203C42CBAE93CFE87DEF158A.gif[/IMG]
You just need an impact driver and a sledge hammer...this link is a crappy one, but you get the idea
http://www.harborfreight.com/cpi/cta...emnumber=93481
There's no way in hell you'd back those screws out with a screwdriver.
Did you end up getting your brakes done?
If you want to get that screw out, you could weld a bolt to the head of the stripped screw, then use a wrench to back the screw out. Use a grade 8 bolt so it doesn't snap on you. The heat from welding would also loosen up that screw some.
haha, I got the pads done. Not the rotors, I guess I will pick up that tool and try it again this summer...Would have been so much easier with that tool. The only other thing that was hard was getting the bolts off that held the caliper in place. I just had my rachet with a hammer and did it that way...
