programming keyless entry remote for 2005 Mazda 6
I have 2005 Mazda 6; manual transmission - 5 speed; 2.3L engine. Just bought a new keyless entry remote control, and do not know how to program it. Can anyone please help. Thank you in advance.
RE: programming keyless entry remote for 2005 Mazda 6
Do you have a keyless entry system where you can keep you key in your pocket and turn the knob to start your car or do you have the key fob where you can unlock and lock your car with it kind of like a viper system but oem?
I have the remote that opens/closes doors and the trunk, as well as the Panic/alarm button.
so you will need to find the order of sequence that you will need to you to reprogam the remote like turning the key 6 times and ending in on is common on most mazda cars but off hand i dont know what the sequence is if you would like can see if i can figure it out.
Yes. I would really appreciate if anyone could tell me what the sequence is for my car. Again, thanks for your help.
sit in the drivers seat with all the doors closed.
open the drivers side door cycle the key from the off to on position 3 times. end with off. leave the key in the ignition within 20 second hit the door button 3 times. its a black button on the bottom of the b pillar the locks will click back and forth once if you did it right. hit any button on the remote you are trying to program twice remote will then be programmed repeat for any additional remotes |
