This is my Transmission Oil Colour
6, 2.3L petrol Sport
It's a little pink, but mainly brown. What do people do? Get a mchanic to replace all of the gear oil (flush), or just drain what comes out - not all will come out - and replace (change)? shttps://cimg8.ibsrv.net/gimg/www.maz...d97b395525.jpg |
Take a photo of the Oil on the dipstick.
Mazda ATF goes brown very quickly, you can't really tell how old or worn it is by colour alone. Does it smell burnt? |
HI. Dipstick is black metal unfortunately. Here it is on paper too. Doesn't smel burned to me. Bought this car at 125,000km, don[t know if ATF oil has been changed. Probably not.[img]https://cimg8.ibsrv.net/gimg/www.mazdaforum.com-vbulletin/2000x1504/80-20180625_211417_007570ba799b93b81e73c34bb27521b740 ac5469.jpg
https://cimg9.ibsrv.net/gimg/www.maz...a31440b57e.jpg |
Doesn't look too bad. No harm in changing it for piece of mind.
4 speed or 5 speed auto? |
(Post 168461)
4 speed or 5 speed auto? youtube.com/watch?v=o690DovjDAc p.s. I need to change RHS CV joint and probably a rear hub/bearing. Seems quite soon at 125kkm. |
CV joints are very uncommon, even the rubber boot lasts a long time.
Rear bearing is bad luck, altho someone may of hit too many curbs &/or pot holes. I used to work for Mazda in NZ & now work for Mazda in Queensland. Mazda Australia has stopped supplying genuine Mazda ATF to suit you vehicle, & instead recommends using Castrol Transmax Multivehicle. |
I had a 2007 Atenza Sports wagon in NZ before moving to OZ. Great vehicle.
Rubber is absolutely perfect. CV is not :( .
I wonder whether the Sport suspension takes its toll on CVs and particularly bearings. Tried to re-lube inner and then outer CV when I started to hear noises - grease was disturbingly liquid - (it started clicking only when engine cold to begin with (could warm vehicle without movement and it would solve clicking) - but now have clicking while turning sharply so I think deifinitely outer CV). My 95 corolla has done 340km and still has original CV's Thanks for tip, will look for Castrol Transmax Multivehicle. s |
Got roof painted when I bought it. Dots of rust on roof. I've heard this is common; hoping it doesn't come back!
