Misfire on 3.0
I have already repaced both vavle cover gaskets, 6 new spark.. plugs, and 6 new ignition coils.....and still have a misfire when I try speed up anyone have other ideas?
Year, mileage please. Any known codes---please list all. How long did you drive with misfires?
Did you change all 6 intake plenum seals: OES Genuine W0133-1639826 Intake Plenum Gasket | Auto Parts Warehouse See also My Pic: Green Rubber Seals. Did you change the throttle body gasket/seal: Mahle W0133-1807640 Throttle Body Gasket | Auto Parts Warehouse . The above should have been changed as intake plenum removal is required to change plugs/ign coils. https://www.mazdaforum.com/forum/mem...off-2-2223.jpg Missfires can be caused by a million and one things: Vac leaks wiring issues spark plugs(even fresh spark plugs that are crappy quality.... E3 and such) Ignition coils alternators(search EMI) MAFS injectors injector o-rings intake gaskets TB gaskets PCV hoses PCVs malfunctioning EGRs Malfunctioning CAS o2 sensors aftermarket intakes intake hoses vac lines Timing chains timing chain tensioner Broken cam gears Malfunctioning cam sensors Incorrect Crank gears(the I4 has like 40 different configurations for whatever reason) incorrect PCM flash issues within the PCM PCM wiring bad diaphram within the FPR issues within the fuel pump dirty fuel filter dirty fuel lines Pre-Cats If the above gaskets/seals have not been changed, change them. Clean your MAF sensor, throttle body. Change your PCV valve and probably that short hose as well. Inspect the intake accordian tube for cracks. Inspect for vaccuum leaks. Put in a good Fuel system cleaner: http://www.redlineoil.com/product.aspx?pid=80&pcid=12 Inspect wires. Re-set ECU after doing above. On the 3.0 ltr V6 the above are easy to do as MAF intake accordian & throttle are removed when removing plenum. PCV is also easier to get to when intake plenum is removed. Clean EGR as well. http://www.youtube.com/watch?v=dmZOn...eo1k3lezmJdHyW After this comes more expensive stuff, so do the above first. |
| All times are GMT -5. The time now is 09:50 AM. |
