Mazda6 won't start
Ran the car normally this morning, got home and parked the car. Went to start agaiin and wouldn't start. All battery functions working. Happened last week, tow truck bumbeed the car got in turned the key pressed tsc a few times and car started.
Dtaz71 |
Define wouldn't start? :confused: The starter motor would not turn the crank or the crankshaft rotated and engine would not run?
Wont start after hot!
Engine doesnt even turn over. Wiring problem I'm thinkin. After wires are jot theres no resistance to starter or fuel pump. ?
Ok so first think is the battery cables both at the chassis, terminal on the battery and to the stater are not making complete continuity. Als the battery should be load test or at best placed on a battery charger to bring it up to 12.5 volts before the next starting attempt.
Car wont start hot
(Post 210115)
Dtaz71 |
