Mazda 6 CAI system. (Cold Air Intake)
Old 07-15-2018, 09:19 AM
Mazda6owner122's Avatar
Default Mazda 6 CAI system. (Cold Air Intake)
Hey everyone.
I'm looking to install a cold air intake on my Mazda 6 2007 first generation. But looking at the engine bay and where my stock air filter is located and the placement of the MAF sensor I ain’t sure if it’s possible. Unless i can somehow get the sensor fitted on to the aftermarket part?
Any ideas?
Air filter marked up in red.
Maf sensor marked up in yellow.
Old 07-15-2018, 09:32 AM
shipo's Avatar
Keep in mind, your factory intake already is a Cold Air Intake. If you opt for an aftermarket unit all you will do is get more noise.
Old 07-16-2018, 02:17 PM
wouldn’t it improve throttle response since it opens up how much air the intake can suck up and the engine to burn?
Old 07-16-2018, 03:57 PM
shipo's Avatar
No, at low power settings there is very little restriction with the factory intake and virtually zero difference between it and an aftermarket intake. The thing is, the factory intake uses sonic tuning to take advantage of intake resonance to enhance mid range torque at the slight expense of top end output (i.e. up near redline at WOT). Under the heading of you have to borrow from Peter to pay Paul, aftermarket intakes typically hurt mid range torque to eek out a couple of horsepower up near redline.
As a general rule, the only thing an aftermarket intake will give you the factory intake will not, is noise.
Paul E. Bridges
06-19-2018 07:04 AM
carid
01-14-2016 05:07 AM
linuxguy0481
04-14-2012 05:25 PM
mazda guy
03-11-2007 05:00 AM
Quick Reply: Mazda 6 CAI system. (Cold Air Intake)
