low beams do not work
anyone else having this problem? my high beams work and my fog lights work. but not my low beams. any help is appreciated, like a wiring schemitic or anything.
Mazda 6 2003 thank you |
RE: low beams do not work
Did you check to see if the bulbs are blown?
i dont think they both would have blown at the same time. but i havent checked yet.. its a mess trying to get to them
Check the fuse before you starting fooling around the bulbs. They are a pain to take out and re-install. Good Luck.
And... check the low beam relay to see if it's working correctly too 'Course if like rx4to6 says, the fuse is blown the relay will not work either. |
You probably already figured out your problem by now, but I bet it is the bulbs. Mine did the same thing. I got my car inspected so I know they were both working, then a week later they were both out. I took it to the dealer thinking that there was some big electrical problem that would be covered under warranty and it cost me $200 for them to change the bulbs. Like someone said above it is a PITA to do it.
I'm having the same problem...how did you fix yours?
I have an '03 6 an have had a sinmilar problem. One of the low beams will go out every 3-4 months or so. I'll replace it just to have the same happen again in a few months. I think the 6 does have some definate electrical problems.
I took mine to the dealership nd they traced the problem back to a bad fuse. I'll see if that was truly the problem 3 months from now.
