LED’s & PCM’s
I do know that there are many owners of the Mazda 6 that have replaced the stock bulbs with LED's and there have been zero issues. It is important that the right ones be used.
https://www.diodedynamics.com/?utm_s...paign=research
Understood. I’m just trying to figure out why I had to replace my oem PCM and then 200 miles later have to replace it again. It’s the only explanation I have as I put those LEDs in a day or two before.
I'm not going to argue but I was under the impression the LED bulb draws less voltage than the standard bulb. I don't see how it could have a negative effect.
The BCM relies on a certain voltage/load, fitting LED's lowers the voltage use/load & this can confuses the BCM. Also the can sometimes spike the BCM.
I'm no expert in electronics, just adding what I know when I can.
