How to change fuel filter on 2009?
Old Mar 13, 2016 | 12:54 AM
Ach3r0n's Avatar
Default How to change fuel filter on 2009?
Does anyone have info on changing the fuel filter on a 2009 Mazda6 i GT? TIA.
Old Mar 13, 2016 | 03:02 AM
Sparky202's Avatar
Fuel filter is part of the fuel pump in the tank. So, are you asking from a maintenance view or are you having a particular concern?
Old Mar 13, 2016 | 03:57 AM
Schedule for replacement is 150,000kms / 90,000miles
Old Mar 13, 2016 | 07:31 AM
shipo's Avatar
Really? I'm surprised as I don't remember my 2009 Mazda3 recommending a fuel filter replacement at all.
Old Mar 13, 2016 | 12:19 PM
Ach3r0n's Avatar
A little of both. The car has 167K on it and is still running the original filter. It runs fine for the most part, but has a little bit of hesitation and idles a bit rough.
Old Mar 13, 2016 | 01:40 PM
Sparky202's Avatar
Spark plug age? Start there if they are over 70k and throw a throttle body cleaning on top of it. Check your PCV hose on the back of the intake and make sure it's not starting to collapse. You may even want to take the IAC, Idle Air Control valve out and clean those passages.
Old Mar 13, 2016 | 02:04 PM
Sparky202's Avatar
Checking myself, The PCV hose concern will only be with the 6 cyl, S model. I think you are saying you have the I, 4cyl.
Old Mar 13, 2016 | 11:05 PM
Ach3r0n's Avatar
I did the plugs last summer so they only have around 10K on them. At that time I found a small'ish leak which was traced back to the valve cover gasket so that was replaced shortly thereafter. Throttle body cleaning is on my to-do list (for my truck as well).
Yes, i GT - 4 cylinder.
Old Mar 14, 2016 | 05:50 AM
Are you sure?
On a 2009 it's located underneath, just in front of the RR wheel arch, and is changed every 40,000kms. ( In my part of the world)
Old Mar 14, 2016 | 08:33 AM
shipo's Avatar
Are you sure?
I no longer have the car so I'm not 100% sure; that said, various maintenance events is something I typically look up when I first buy a car, and I am reasonably certain I never saw any reference to a fuel filter replacement.
