-   Mazda6 (https://www.mazdaforum.com/forum/mazda6-20/)
-   -   How to adjust headlights (https://www.mazdaforum.com/forum/mazda6-20/how-adjust-headlights-3532/)
06BLACKSPORTS Jun 4, 2006 02:15 AM
My right headlight beam seems to aim right after installing an aftermarket HID kit. Would anyone have any ideas how to move the beam from the right more towards the left?
I found the screw that moves them up and down, but cannot seem to find a way to move the beam left and right.
Thanks
Billfrompa Jun 5, 2006 10:25 PM
RE: How to adjust headlights
The left and right adjustment is way under the fender....get a flashlight and look.... I took a 6mm allen wrench...hacksaw the long end off at half an inch. ( not easy, by the way) Tie a string around it...you will drop it a couple of times...Mine is still down there somewhere in the inner fender! Someone with small hands can reach in and put one end into the back of the adjustment wheel. spray a shot of wd-40 or something on the gears...once you break it loose it will turn ok...but it's hard to start because you can barely get one finger on it! Then turn it one way and watch the lights to see which way they are moving. A real Mazda mechanic will have a better way to do this, I'm sure. You're supposed to be able to put a # 2 phillips into the adjustment gears and spin it, but good luck getting back under the fender!
Billfrom pa
Tracker Jun 6, 2006 12:55 AM
does that also work with the 3 cuz my drivers side lights are pointing downwards.
06BLACKSPORTS Jun 7, 2006 01:04 AM
well i just stuck my hand under and gave the gear a spin and sure enough it moved.
Tough thing is, I still dont know if one light is aiming higher due to the bounching effect the projectors have.
But i cant ask MAzda to check my leveling because I have aftermarket HIDs?
bahhhhhhhhhhhhhhhhh
