Horns not working from steering only Mazda6 2007
Old Apr 25, 2022 | 07:39 PM
jean-marc's Avatar
Default Horns not working from steering only Mazda6 2007
Hello to all; On my 2007 Mazda 6 the horn is no longer working when use from the steering wheel : ie : works fine when locking the doors with remote (horn comes on ) So the relay, horns, fuse ,etc from inside the engine are Ok; But when using the horn from inside: nothing(relay not cliking neither) I suspect maybe (but i could be wrong..) clockspring or else .(BCM..). or...All others functions from steering are ok ; I am not too keen to dismantle the steering , is there a way to diagnos. this or i am totally out and far from the causes of problem..? Thanks .
Old May 9, 2022 | 10:16 PM
jean-marc's Avatar
Update : I just find out that when the immobilyser red sign (key logo ) lit on , the horn seems to work from steering operation... The thing is that the red key sign lit like partially, not fully lit... So whenever this sign comes on , the horn is operational ; I think both horn and immob. are going through the BCM module.. Maybe not relevant, i dont know; Also if the clockspring was in cause , would it be any other functions not working..? In my case only horn does not operate.. I am quite lost with this horn situation from steering .. confuse me...
Old Aug 26, 2022 | 08:26 PM
jean-marc's Avatar
Any Thoughts on this matter ..? Thanks really ..
Old Sep 7, 2022 | 06:07 PM
jean-marc's Avatar
Hello all
Is there anybody who had seen this problem before : the horns works when using the remote-key fob ( locking doors button push twice) but no horns from steering wheel ;I did remove the steering and everything looks fine, at least as is ;NO other malfunctions from steering controls ,(audio radio cruise etc ) only horns not working .. So: clock spring or Body control module or..other ..? Thanks ; Mazda 6 2007 wagon.
Simon75
Jun 7, 2020 07:27 AM
Xynerate
May 9, 2012 11:02 AM
lorigirl
Dec 3, 2007 10:04 PM
98mazda
Jun 23, 2006 02:48 AM
