-   Mazda6 (https://www.mazdaforum.com/forum/mazda6-20/)
-   -   horn doesn't work... ck'ed a few things, at a loss (https://www.mazdaforum.com/forum/mazda6-20/horn-doesnt-work-cked-few-things-loss-48535/)
tff Nov 20, 2021 12:56 PM
My 2007 Mazda 6 horn does not work. What I've checked:
-Fuse is OK
-Relay does click when the horn button is pressed. I also swapped the relay with another one, with no benefit.
-Connected new horn, still doesn't work.
So... any idea what my next step should be? Thank you.
user 7239287 Nov 21, 2021 05:39 AM
-Fuse is OK
could be a bad negative from the the horn, run a wire from the negative on the horn to the negative on the battery, then press the horn and see if that makes a difference.
tff Nov 21, 2021 07:09 AM
Thank you for that. Where exactly is the negative on the horn - I assume it's just the mounting bolt/attachment of the horn assembly?
user 7239287 Nov 21, 2021 09:18 AM
yes, check around that area, it could be corrosion.
Callisto Nov 21, 2021 09:39 AM
After check the power lead and the ground continuity as suggested earlier.
Using a volt/ohm meter have an assistant push the horn. As you have said you can hear the rely so that circuit is getting power and the steering wheel is not the problem. By passing the horn you should read voltage from the horn wire. If not the problem is between the relay and the horn. There is nothing else that wire runs so you can either trace the wire in the harness for damage or simply run a new wire from the horn rely to the horn.
tff Nov 21, 2021 01:10 PM
Thanks for the info.
Turns out it was the horn. I replaced the horn and now it works. I think when I tested the new horn previously (uninstalled) I didn’t ground the horn bracket. All good now.
user 7239287 Nov 21, 2021 01:15 PM
glad you have it sorted.
Callisto Nov 22, 2021 09:52 AM
Thanks for returning and letting us know you solved the problem
rururustis May 21, 2024 07:10 AM
So, you've checked a few things already, huh? Nice work! It's always good to rule out the easy stuff first. But if the horn's still MIA, it might be time to dig a little deeper. Sometimes those gremlins like to hide in the most unexpected places!
Now, about that Milwaukee air horn... Hmm, interesting choice! Gotta say, it sounds like it could add some serious flair to your ride! But before you go all-in on the upgrade, let's make sure we've exhausted all our options with the current setup. Can't hurt to give it one last shot, right?
So, my two cents? Keep troubleshooting like a champ, and if all else fails, well, maybe it's time to give that Milwaukee air horn a shot!
