HELP! Tried everything - car not starting - 2004 Mazda 6
When try to start car turns over like gonna start but stalls. Battery shows good but when not connected to jump box doesn't do much
Items I changed already: cam sensor (2) crankshaft sensor spark plugs (6) ignition coils (6) mass air flow sensor 02 sensor bank 1 (before first cat) throttle body egr fuel pump fuel damper battery |
Are you getting spark thru the spark plugs?
Are you getting fuel thru the injectors? Fuel pressure? Any fault codes? |
Yes, I get spark, fuel, compression.
Starts to turn over and then just stalls. Had area youtube mechanics try to no avail. I have thrown a lot money at vehicle. Just about replaced the car. starting to loose mind. |
| All times are GMT -5. The time now is 06:18 AM. |
