Help!!!!!. How do i remove the stereo from my mazda 6. 2003 model.
If anybody has a step by step guid. This would be greatly appreciated as i am fitting a parrot hands free kit.
Thanks in advance. Lee. |
RE: Help!!!!!. How do i remove the stereo from my mazda 6. 2003 model.
Remove shifter knob (spin off),
Remove the cupholder/shifter bezel (AT or stick?) by pulling up (There are wire harnesses attached to the shifter bezel if it's an AT, pull the lightbulbs out of the sockets by rotating 90 degrees. There are tabs that keep the shifter bezel and cupholder together, you'll need a key or screwdriver to push on the tab to unlock the 2 panels. Once those 2 panels are out, remove the screws along the bottom edge of the radio, pull out on the bottom edge of the radio, then wiggle the assembly out of the dash (The top box will stay in the dash.) |
Thanks for your help guys.
