Flasher relay location
Old May 22, 2015 | 05:52 AM
Cofe's Avatar
Default Flasher relay location
My 2006 6s power door locks, turn signals, emergency flashers, and door actuated interior lights have stopped working. I am suspecting the flasher relay is the problem but cannot locate where it is. I checked all the fuses and they are ok. Anyone know what can cause this, and where is the flasher relay located? ... Here is a pic of what I am suspecting is the flasher relay. Is it the white box with one bolt to the frame located under the drivers side dash next to the brain?...Help!!!
Old May 22, 2015 | 09:42 AM
No separate flasher relay. It's all controlled by the ECU.
Old May 23, 2015 | 05:07 AM
Looking in the workshop manual I believe the indicators are controlled by the Body Control Module (BCM), which on a RHD vehicle is in the passenger footwell/kick panel.
Old May 23, 2015 | 01:28 PM
Cofe's Avatar
Thank you for the information. The sad part is that a dealer quote on just the BCM is $425.00 without labor.
Old May 24, 2015 | 07:40 AM
I would suggest getting a code check down on the BCM.
Old Jun 5, 2023 | 06:45 PM
andres's Avatar
YES THATS IT!!! the impossible flasher relay location is in the same for a 2008 mazda 6
Daboxx
Mar 4, 2015 10:42 AM
MPaws
Feb 24, 2013 08:44 PM
pitbull357mag
Nov 2, 2010 03:27 PM
tonto26
Mar 13, 2008 08:51 PM
supercrisp
Mar 27, 2007 10:08 PM
