Engine can not rev
Old Dec 29, 2015 | 01:53 AM
GigerStrife's Avatar
Default Engine can not rev
Hi Guys,
I have a 2005 Mazda 6 TS2 143hp diesel that has developed an issue.
The engine will not rev above 2000-3000rpm in any gear. When it reaches said revs, it drops to idle again. If you sit in neutral with your foot on the accelerator the engine just cycles (Revving to 2000rpm and then back to idle and so on)
I can easily take the car to 70 providing I change gear before 2000rpm.
I have attached my scanner to the car which has revealed no fault codes. I have no lights on the dash either.
I have tried cleaning the MAF with carb cleaner to no avail.
Just to mention this car has had the Cat and DPF removed by previous owners.
Thanks,
Pete
EDIT: Just a little extra info.
It happens regardless of time of day and whether the engine is hot or cold. It happens in every gear. I can easily get the car to 70mph providing I keep the gear changed below 2000-3000rpm. When the car is kept below these revs it acts as normal.
The car has 113,000 miles (Approx 182,000 km) on it. The engine has been refurbished recently around 10,000 miles ago due to a rod bearing going.
I only noticed the DPF was removed when I had an Oxygen sensor go faulty. It appears there is a straight pipe welded in place of the Cat and DPF. The three sensors that usually sit in the Cat (Beginning, middle, end) have been removed and the wires are in a small box zip tied under the car (Haven't opened the box yet.).
There is a cigarette pack sized black box zip tied by the battery in the engine compartment. Upon opening it appears there is a USB port and a serial connector. The serial connector has been spliced into a wiring loom, with a white wire strung across the engine bay to an electrical connection on the left of the common rail system.
I am in the UK.
Hope this helps.
Thanks,
Pete
Old Mar 15, 2022 | 12:24 AM
mazda3grandma's Avatar
i have a 2006 mazda 3 touring automatic and has no power at all no revs when i put my foot on gas petal
Old Mar 15, 2022 | 12:29 AM
I have a mazda 3 touring it started fine after work but after driving it seemed like i was losing power and when i would come to a red light it seemed like the car wasn't shifting into gear even my windshield wipers were slow. shut radio off heater and when i stopped , and shut car off it wouldn't start . got a boost thinking it was my battery but started fine but when i put it in gear no power and no revs
Old Feb 17, 2025 | 09:08 AM
Abell's Avatar
Originally Posted by GigerStrife
Hi Guys,
Thanks,
Pete
I am in the UK.
Hope this helps.
Thanks,
Pete
what was the issue,i have the same problem(sory for my english)
Old Feb 17, 2025 | 12:17 PM
I suggest that you star your own thread as NO 2 vehicles have multiple issue that are the same. The other thing is the last time this thread was responded prior y to your was Mar 14, 2022 10:29 PM
Old Feb 17, 2025 | 12:23 PM
Wait I see I already responded to you, and you totally ignored my suggestion and posted on yet another VERY OLD THREAD Good luck with your problem!
Apparently, I will not waste my time helping you because you cannot even follow simple recommendation let alone anything that may be more technically challenging?
limp mode - Mazda Forum - Mazda Enthusiast Forums
Markus2
Aug 19, 2021 06:32 AM
tombuc1
Mar 31, 2020 10:38 AM
gchusonis
Nov 17, 2017 07:37 PM
kunc
Mar 22, 2014 02:33 AM
