EGT Sensor failure
Old Feb 21, 2025 | 10:03 PM
mtmiet's Avatar
Default EGT Sensor failure
Hi,
I Have Mazda 6 2.0TD (MZR-CD) from 2008 (280 000km). The middle exhaust gas temperature sensor on dpf has failed. It show 143 deg C (other two show 50 deg C) in room temperature and 650 deg C (other two 200-250 deg C) when normally driving. And when measured the ohms it shows lower numbers than the other EGT sensor. Those causes that dpf regen doesn't go through.
Apparently there are only OEM EGT sensors available but those are way too expensive. Does anyone know that do the same age Mazda 6 sensors fit the car electrically? Meaning that do those have same ohm chart? I can make new connections but would like to know does Mazda 3 sensor give correct values to ECU? Thanks for any help.
davidthelodge
Sep 8, 2024 03:10 AM
DaniGav
Sep 1, 2024 02:34 PM
Jimbo806
Apr 13, 2019 04:30 PM
Kevin Mason
Apr 13, 2019 08:01 AM
Big Julius
Dec 14, 2018 04:38 PM
