EGR solenoid valve
I am trying to locate an EGR solenoid valve for my 2003 6 with 2.3 ltr engine. Recently replaced MAF sensor and found vacuum leak in one of the two EGR solenoid valves. Also would that cause misfiring?
Is this what your looking for ?Do you have any codes coming up?Not sure if it would MIS fire.But wouldnt run good because you would have a vacum leak where the crack is.I bought a Purge Control solenoid from here that worked for my 1996 millenia
http://www.redlinemotive.com/store/r...acuum+Solenoid |
