EBC Green Stuff Pads & Raybestos Rotors
Recently put these on my 2006 Mazda 6 on all 4 wheels. So far these are awesome. Still in break-in period and will update. Got rid of cross-drilled rotors after 5 years, they didn't work good after 1st year and cross-drilled rotors were bad in winter.
EBC "Green Stuff" Pads Series 2000 Front is part # DP21765/2; Rear Part # DP21766 .
Raybestos Rotors Front part # 680404; Rear part # 980172. They are painted black in the middle hub area, but not quite enough as you can see some rust where brake pad is not touching rotor surface area.
Designed for premium street driving offering better brake effect up to 600°C (1100°F). EBC Greenstuff Series 2000 has a high initial brake effect and gives drivers confidence from first application of the brake pedal. There is no such thing as a no dust pad. The very nature of how a brake works requires that some dust be generated to avoid rotor vibration (shimmying). The EBC pad creates less dust and dust is more easily washed off than most. All pads create more dust as they are bedding in especially if rotors are worn. Nominal friction coefficient 0.55.
Red Stuff:
For heavier faster cars and vehicles above 200bhp we strongly recommend Redstuff which does offer much less dust. EBC Redstuff is a Ceramic Low Dust pad. Redstuff brake pads are however as a harder compound does take longer to fully bed in to achieve its highest levels of performance (can be up to 1500 miles/2500 Kms urban use) during which time the odd “Chirp” of brake noise may be heard when starting from cold in damp and cold conditions at walking pace speed.
Green Stuff:
Green Stuff features red “brake in’ surface coating for instant safe braking after install.
EBC medium dust fast street pad with 20-25% % brake improvement.
Capable of repeated heavy brake use without brake “Fall-Off”.
Very minimal disc/rotor damage characteristics.
Superb material for lighter model Asian and European sport compacts.
Special compound ingredients that prevent 'outline etching' eliminating brake stiction onto the rotor in damp conditions.
The latest version of Greenstuff brake pads are a deliberately softer compound to improve pedal feel on lighter cars at lower speeds. This resulted in a medium dust material with good lifetime and minimal rotor wear.
Just cleaned and waxed the rims for nice pic! -- Reflection of brakes!
Red Stuff:
Green Stuff:
Brake dust came off real easy with dish soap and a J-Cloth.
Previously I did put car wax on the rims---this probably helped the easy cleaning.
Going to Delaware Speedway tomorrow to watch a buddy race. At least my rims are clean!
carid
Mar 18, 2015 08:15 AM
ultrarevvin1
UltraRev
Jan 14, 2014 10:24 AM
ultrarevvin1
UltraRev
Jan 14, 2014 09:31 AM
ultrarevvin1
Jan 11, 2014 07:17 PM
RockAuto
Jan 23, 2013 04:36 PM
